Plugin Suites
Families of plugins by the same authors
Muse FX
A collection of essential effects. Contains a Chorus, Compressor, De-esser, Delay, Master, Noise Gate, Pitch Fix, Reverb, Rotary, and two EQ effects.
MuseFX is a free and expanding collection of high quality plugins for Audacity, MuseScore 4 and any VST3 compatible host. MuseFX brings the tools you need to elevate your mix to a higher level.
Download Muse hub
MuseFX can be downloaded from the "Effects" tab in the Muse Hub
Available for all platforms
GVST
A set of simple VST effects, most known for the GSnap (auto-tune) effect.
Download page
Available for Windows and macOS
MFreeFXBundle
A collection of 37 effects in categories like Analysis, Saturation & distortion, Dynamics, Equalization, Mastering, Mixing, Pitch and others.
Download page
ToneBoosters
Powerful plugins for any type of audio mixing: eq, dynamics, reverb, and more.
Download page
Details
"Demo" mode is fully functional except for preset saving. You can use Audacity's preset system instead.
What is Included:
  • Barricade 4 : Limiter
  • BitJuggler : Sampler / Processor
  • Compressor 4 : Dynamics processor
  • Dual VCF : non-linear filters
  • Enhancer : preset filter eq
  • Equalizer 4: Digital remasterd Anolog dynamic eq
  • Flowtones : synthesizer
  • GonioMeter : Stereo Image Analyzer
  • MBC : Multiband Compression and saturation
  • Morphit : Headphones correction and personalization
  • ReelBus 4 : Magnetic tape recording, echo and flanger simulator
  • Reverb 4 : Lush reverberation and shimmer
  • Sibalance 4 : Spectral de-esser and harshness remover
  • Spectogram : Insightful time and frequency visualization
  • VoicePitcher 4 : Vocal doubling, pitch shifting and freezing effect
Kilohearts Essentials
Kilohearts Essentials is free collection of 30+ plugins.
Download page (requires registration)
Available for Windows only
Reaplugs
A selection of some effects found in Reaper.
Download page
Intel OpenVINO
Music separation, remix and generation, noise suppression, and transscription
Available for macOS
MacOS already ships with a range of Audio Unit effects which you can try out
Available for Linux
swh Plugins
A set of LADSPA effects. They can be found in most Linux repositories.
Calf Studio Gear
An LV2 plugin suite featuring a wide array of plugins for audio mixing and mastering. As of version 0.90.0 there are 47 plugins in the suite.
Note: The virtual instruments included are not supported in Audacity.
The Calf plugins can be found in the repositories of most Linux distributions, additionally, compilation instructions can be found here:
Last updated
