A multi-purpose dynamics processor, can be used for EQ, compressor, gate and noise reduction purposes. Part of ReaPlugs.
Details
Copyright (C) 2006-2016, Cockos Incorporated VST PlugIn Technology by Steinberg Media Technologies GmbH
Information from the vendor:
FFT based dynamics processor
Supports FFT sizes of 128-32768
Useful in/out frequency response display
Supports defining response curves both using any number of points, or freehand mouse
EQ - can be used as a linear phase mastering EQ, or as a super-effective surgical EQ
Compressor - can compress at a fixed ratio with a per-band threshold
Gate - can gate with per-band threshold
Subtract - can build noise profiles and subtract noise from the signal
MCompressor
Details
MCompressor provides refined compression. It features an adjustable compression shape, giving you the power to create dynamic sound effects, and a range of up-sampling options for a crystal clear sound.
Advanced GUI
Compare multiple settings: A to H Switching and A to D Morphing.
Unique visualisation engine with classic meters and time graphs
MIDI controllers with MIDI learn
M/S, single channel, up to 8 channelds surround and up to 64 channels ambisonics processing
Extremely fast, optimized for newest AVX2 and AVX512 capable processors
Supports VST, VST3, AU and AAX interfaces on Windows and macOS
