> For the complete documentation index, see [llms.txt](https://plugins.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://plugins.audacityteam.org/ai-plugins/ai-plugins.md).
# AI plugins
## Intel OpenVINO
A set of AI-enabled effects, generators, and analyzers. These AI features run 100% locally on your PC 💻 -- no internet connection necessary! [OpenVINO™](https://github.com/openvinotoolkit/openvino) is used to run AI models on supported accelerators found on the user's system such as CPU, GPU, and NPU.
* [**Music Separation**](https://github.com/intel/openvino-plugins-ai-audacity/blob/main/doc/feature_doc/music_separation/README.md)🎵 -- Separate a mono or stereo track into individual stems -- Drums, Bass, Vocals, & Other Instruments.
* [**Noise Suppression**](https://github.com/intel/openvino-plugins-ai-audacity/blob/main/doc/feature_doc/noise_suppression/README.md)🧹 -- Removes background noise from an audio sample.
* [**Music Generation and continuation**](https://github.com/intel/openvino-plugins-ai-audacity/blob/main/doc/feature_doc/music_generation/README.md) 🎶 -- Generates music from a text prompt or continues an existing song
* [**Whisper Transcription**](https://github.com/intel/openvino-plugins-ai-audacity/blob/main/doc/feature_doc/whisper_transcription/README.md)🎤 -- Uses [whisper.cpp](https://github.com/ggerganov/whisper.cpp) to generate a label track containing the transcription or translation for a given selection of spoken audio or vocals.
{% embed url="<https://github.com/intel/openvino-plugins-ai-audacity/releases>" %}
Download page
{% endembed %}
## NVIDIA Broadcast
A virtual device that sits between your microphone and Audacity and other programs which allows you to use an AI denoiser.
{% hint style="warning" %}
**Caution:** NVIDIA Broadcast only works on Windows machines with a NVIDIA RTX GPU.
Further, it only works on spoken word content; musical content is treated as noise and filtered out.
{% endhint %}
{% embed url="<https://www.nvidia.com/en-gb/geforce/broadcasting/broadcast-app/>" %}
Download page
{% endembed %}
<details>
<summary>Details</summary>
Copyright © 2022 NVIDIA Corporation
Requires NVIDIA GeForce RTX 2060, Quadro RTX 3000, TITAN RTX or higher
Full setup guide: <https://www.nvidia.com/en-gb/geforce/guides/broadcast-app-setup-guide/>
Technically, NVIDIA Broadcast isn't a plugin but a virtual device. You will find it in Audacity's audio settings as an input. It does not show up in the Plugin Manager.
</details>
